Front seal question
Old Apr 4, 2007 | 10:27 PM
Z28LT1_Just_Nasty's Avatar
Front seal question
Figure while I got everything apart up front I might as well change the front seal. Its not that major of a leak but why not get it done now.
My question is, should I expect oil to pour out? I JUST changed the oil, literally haven't even cranked it yet with the new oil. I'm making a trip to get a new opti tomorrow and while I'm there I just want to know if I'm going to need more oil.
Ryan
Old Apr 4, 2007 | 10:45 PM
Oil won't pour out.
Old Apr 5, 2007 | 08:44 AM
transAMdriv3r's Avatar
you should have waited on changing the oil, you may get dirt in there. You should be okay if you wash the front of the motor down. Its better to be safe than sorry.
Old Apr 5, 2007 | 09:38 AM
afr lt1's Avatar
or just drain the oil and put it back when your done.
Old Apr 5, 2007 | 12:03 PM
I wasn't originally intending to do the seal, but decided once I had everything off, I decided hey why not. At that point I had already changed the oil it was just spur of the moment.
Old Apr 5, 2007 | 12:17 PM
TQdrivenws6's Avatar
As long as you didn't put in 15 quarts it shouldn't leak out
I wouldn't worry about the dirt so much, just clean the area real well before you pull the hub and put the seal right on and the hub back in before anything has a chance to get in there.
Brake_L8
Jan 20, 2015 09:44 AM
Jazsun
Dec 29, 2014 12:14 PM
Hurin
Dec 13, 2014 07:38 PM
The Seer
Nov 20, 2014 06:32 AM
