Front seal changing question.
Old Sep 23, 2004 | 07:13 PM
80TA's Avatar
My front seal appears to be leaking.Can you change it once you take off balancer does it go in from front or what exactly do I have to remove to change it out?
Talking about my lt1 here of course guys.
Old Sep 23, 2004 | 10:50 PM
Re: Front seal changing question.
You have to remove the balancer/pulley and hub. The hub can be a little tricky to get off, as it is not wide open in the middle like an SBC balancer. A longer high grade bolt, threaded into the crank snout can give your puller something to push against when removing the hub. I suggest you search about pulling the hub, so you know what you might be up against.
Magenta_Hearts
Mar 29, 2017 08:54 PM
alex5366
Feb 17, 2015 10:43 PM
Brake_L8
Jan 20, 2015 09:44 AM
Jazsun
Dec 29, 2014 12:14 PM
