Front Lights replacement
Okay, I drive home from work in the dark everyday and I am getting sick of turning on my brights so I can see while going around a corner. Is there an aftermarket company that makes a good light replacement for the 93-97 camaro?? Thanks
Or spend $250 and get the best lights I've ever owned -- Hella 90mm projectors. I fabbed up custom brackets to mount them and I think the round lights look dang good. Course they make the factory fogs look like POS. They're next to be swapped for a set of Hella FF50s.
Way better beam pattern than any other light I've seen/tried and they're even legal!
Check out Sam95zNoTop's thread on best headlight upgrade in Appearance forum for more info.
Hurin
Dec 13, 2014 07:38 PM
