Front left wheel sensor?
Old May 3, 2004 | 10:29 AM
ASIM's Avatar
Hey guys:
Got the ABS and traction light on in my 95 Z28. Scanned it and got the front left wheel sensor. Tried cleaning the connector, but no go. I understand that the sensor is not changable with replacing the bearing. Is that true? Anyone had this before and have any suggestions.
Thanks very much.
Asim
Old May 3, 2004 | 10:37 AM
LPEdave's Avatar
Right, you'd have to replace the whole hub. You might also double check the pins to make sure they're contacting well before you toss the old one out.
Dave
Old May 3, 2004 | 12:26 PM
TobyZ28's Avatar
How hard is it replacing the hub? i have the exact same problem, Front Left Wheelspeed sensor.
Old May 3, 2004 | 12:47 PM
LPEdave's Avatar
Given that pads and rotors are on your to-do list, you'll be more than halfway there.
1. Remove wheel
2. Unbolt and suspend caliper
3. Slide off rotor
4. Unbolt hub (4 bolts)
reverse to re-install. Make sure the hub bolts are torqued and lock-tite'd.
Dave
Old May 3, 2004 | 01:16 PM
TobyZ28's Avatar
1. Remove wheel
3. Slide off rotor
Dave
Thanks Dave, unfortunatly ive just got my rears to do for breakes and pads
But sounds easy enough, I've had the calipers off before so it shouldn't be a problem.
RUENUF
Mar 13, 2016 03:39 PM
rjc1629
Jan 27, 2015 10:46 AM
squarehead
Jan 15, 2015 07:02 PM
BigED
Jul 26, 2002 09:22 AM
