Front left wheel sensor?
Hey guys:
Got the ABS and traction light on in my 95 Z28. Scanned it and got the front left wheel sensor. Tried cleaning the connector, but no go. I understand that the sensor is not changable with replacing the bearing. Is that true? Anyone had this before and have any suggestions.
Thanks very much.
Asim
Thanks very much.
Asim
Given that pads and rotors are on your to-do list, you'll be more than halfway there.
1. Remove wheel
2. Unbolt and suspend caliper
3. Slide off rotor
4. Unbolt hub (4 bolts)
reverse to re-install. Make sure the hub bolts are torqued and lock-tite'd.
Dave
1. Remove wheel
3. Slide off rotor
Dave
1. Remove wheel
3. Slide off rotor
Dave
1. Remove wheel
3. Slide off rotor
Dave
But sounds easy enough, I've had the calipers off before so it shouldn't be a problem.
squarehead
Jan 15, 2015 07:02 PM
