friend is stranded please help!!!!
Old Dec 18, 2003 | 11:24 PM
camarokid24's Avatar
My friend has a 93 geo merto front wheel drive with front disk brakes and is stranded and I need your expert advice .....I know that this forum is for camaros. I have a camaro and I am on here all the time so this is the only place that I could think of to get advice . here is the simptoms .....he was on his way to work and heard and felt a thunp comming from his left front wheel and when he was a couple of blocks from where he works he started to hear grinding noises. thought it might be brake pads , took off the wheel and inspected the pads and found that they are still good. also he found small metal shavings. He found that the hub has a lot of slop in it as well. what could be causing this ? Please any help would be greatly appreciated. Thanks guys
Old Dec 18, 2003 | 11:33 PM
ZDriver96's Avatar
wheel bearing...
Only thing that I can think of.
Its the only thing spinning back there..
If there is slop in the hub then i'd almost be sure its the wheel bearing.
*edit* my bad i thought u said from the rear...??? its late....
axle / halfshaft or wheel bearing.
Old Dec 18, 2003 | 11:34 PM
stereomandan's Avatar
Sounds like his half axle to me.(connects the wheel to the tranny.)
Dan
Old Dec 18, 2003 | 11:47 PM
thanks alot for your advice guys. I was thinking it might be the bearing...I really appriciate all of your help guys .
HAWG
Sep 25, 2015 11:41 AM
mark0006
Sep 14, 2015 12:35 PM
Bxlt1
Sep 10, 2015 08:16 AM
rideordie
Sep 7, 2015 08:22 AM
