fresh build
Old Nov 23, 2007 | 09:06 AM
QUIT's Avatar
fresh build
I have just finished build on "383" stroker. Car will be daily driver and see some strip time. Installed Comp Cams 292XFI. Was wondering if anyone has any input on this cam. Car has not been tuned yet, so I really don't know what to expect. I am hoping for 450-470 rwhp.
Old Nov 23, 2007 | 09:21 AM
96capricemgr's Avatar
Your rwhp expectations are WAY WAY too high, might make that FWhp.
That said the XFI stuff is not delivering as well as it's repuation would suggest. It is the latest and therefore everyone assumes greatest, results are proving thaty to not be the case.
You will at least have a mailorder tune in it before running it right?
Old Nov 23, 2007 | 09:26 AM
danhr's Avatar
ummmm i think you will be more realistically at 420 rwhp.
Old Nov 23, 2007 | 09:29 AM
QUIT's Avatar
fresh build
Car will be dyno tuned by Geof Skinner @ Thunder Racing.
Old Nov 23, 2007 | 09:42 AM
Can you get him to do a quick baseline if you bring him the pcm first? I would not drive it without a tune. If you absolutely have to move it I would unplug the MAF so that the extra cubes and the larger injectors can to some degree cancel eachother out. If the MAF is hookedup the pcm will try and fuel it as if it still has 24lbs injectors and will grossly overfuel it.
What I am suggesting is NOT good enough to drive it, just to move it.
Old Nov 26, 2007 | 01:13 AM
slomarao's Avatar
he might hit 450rwhp. Hes got afr 210's and a lt4 intake, if those are both heavily worked i dont see his goals being unrealistic. idk about 470 tho, pushin it
Old Nov 26, 2007 | 01:38 AM
speed_demon24's Avatar
Compressions on the low side for a cam that big too.
Novo
Jun 14, 2016 02:58 AM
CARiD
Sep 30, 2015 05:44 AM
pepon214tx
Sep 20, 2015 04:48 PM
DelSoto
Sep 19, 2015 05:31 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
