freeze plugs
Old Mar 27, 2008 | 02:32 PM
blackz151's Avatar
freeze plugs
gettin ready to put frezze plugs in my new block. just wanted to know the best place to get them from. Thanks
Old Mar 27, 2008 | 02:34 PM
mdacton's Avatar
any machine shop should have them locally.....a kit with everything.
an auto parts place would have just the freeze plugs
The_Bishop's Avatar
I make sure I was using brass, and seal it with Permatex hardening sealer.
Old Mar 27, 2008 | 04:57 PM
Mikey97Z's Avatar
Don't forget the silicone
Old Mar 27, 2008 | 05:44 PM
9formula4's Avatar
did you have the block machined?? If so they should have already installed them. My shop installs them as soon as the block is done and cleaned.
Old Mar 27, 2008 | 07:43 PM
The_Bishop's Avatar
Don't use silicone. Clean everything with solvent (brake cleaner and/or acetone) to thoroughly degrease it, and use Permatex hardening sealer. Silicone will not seal as long or well as the Permatex.
KYWes
Jun 14, 2022 06:52 AM
94Z28LS1toLT1
Oct 4, 2015 11:28 PM
Xiantyl
Jul 21, 2015 05:42 AM
gonzo275rltw
Jul 11, 2015 04:19 AM
