Freescan download ......tried comp forum.
Old Oct 8, 2003 | 11:50 PM
S.J.S.'s Avatar
Hey guys I'm sure I aint the only had this problem. I have an old laptop which I'm gonna use on my car and its not internet ready. I have a desktop at home. Is there a way to download it to my desktop then to my laptop. I tried already but I guees once you install it on your desktop you can't transfer it. Dunno I aint a comp whiz. sorry.
Old Oct 9, 2003 | 01:16 AM
PoorMan's Avatar
You need some type of removable media that will hold the 5-6 mb file to transfer it to the laptop. Or, you can transfer it via a crossover RJ-45 network cable, a serial, or a parallel cable. That's your only options I believe. Since you have an "old" laptop, the cheapest (slowest) way would be to use a serial or parrallel cable. Do a google search on setting up a network connection using serial or parrallel cable. It's pretty easy.
Jeff D.
Old Oct 9, 2003 | 01:54 AM
S.J.S.'s Avatar
Wow.....now I know that I'm a comp idiot. Didn't anyone else have that problem?????
Old Oct 9, 2003 | 02:10 AM
madwolf's Avatar
You can archive it and have it split into several 1.44 MB volumes. (So that it will fit on floppy disks)
Then use a couple of floppy disks to transfer the volumes, or you can use one disk to copy one file at a time, then once you get it transferred to the laptop, erase it, then copy it from the computer again and do the same until you're done. Should take 3 times. (not quite sure about how much space freescan takes)
You can download WinAce from www.winace.com and use the trial version to do this, or if you still don't know how to do it, PM me and I'll split it for you, then post the split files on my server so you can save them on floppies.
Old Oct 9, 2003 | 03:07 AM
S.J.S.'s Avatar
Hey ION....My laptop got a CD drive on it. It aint that old But when I burned it to the Disc and tried to transfer it the program wouldn't let me install it onto my laptop. Next thing I knew It said I had a disk problem and my comp never worked since. My frined thinks its my hard drive.
Old Oct 9, 2003 | 07:56 AM
You have to copy the install program that you downloaded, not the program after it is installed.
Old Oct 9, 2003 | 08:17 AM
S.J.S.'s Avatar
You know that's what I was thinking and I thought I did that but now I know I didn't.
Thanks guys.....that last answer was the one I needed.
13qtr
Oct 28, 2016 08:11 PM
football4life
Oct 4, 2015 07:48 AM
sh0ckl3y_z28
Oct 3, 2015 06:34 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
