Fram filter and oil pressure
Old Jun 13, 2004 | 02:32 PM
SplitFire's Avatar
A while ago, I had floored my car and when I came to a stop, my oil pressure read zero. I turned the car off, started it back up, and it ran fine, but after sitting for a while, the check gauge light would come on and oil pressure would be back in the red. I changed my oil sending sensor hoping that was the problem. Since then (it has been about 8 months), my oil pressure has never gone into the red, but usually hovers right above it.
When I start my car in the morning, oil pressure is on the third line but then makes its way down below the first line. Oil pressure also does not move no matter how much gas I give it.
Is it possible that it could be the FRAM oil filter I'm using? I just changed my oil yesterday, so if I were to replace just the filter, how much oil would I lose.
I also run 10w 30 mobile 1.
Old Jun 13, 2004 | 02:46 PM
bunker's Avatar
All Fram filters fall apart in no time in our cars, i've had my share, same crap happens.
Old Jun 13, 2004 | 03:01 PM
bunker's Avatar
if you have an oil cooler that might help, I've never had a successful one.
Old Jun 13, 2004 | 09:05 PM
SplitFire's Avatar
Thanks for the replies. It'd be nice if a filter change would fix my problem, but I doubt it too.
Old Jun 13, 2004 | 10:09 PM
Spinner's Avatar
Time to check if you still have your oil pickup attached to your pump. Drain the oil, and look around in the drain plug hole for it. Tap the pan hard and listen for something metal clattering. You'll know then.
Looks like you might have kicked out the pickup when you went WOT. Get it stuck back in, and tacked into place before something bad happens
HectorM52
Jul 30, 2017 11:46 AM
Dmonty
Jun 2, 2015 11:19 PM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
Jul 4, 2005 05:00 PM
