fouling sparkplug
fouling sparkplug
I keep fouling out the #6 sparkplug. I just installed my new engine and can't figure out what is causing this. I thought I might have a header leak because black dust was above that cylinder so I replaced the header gasket and sparkplug and it started fouling out again after only driving it about 10 minutes. I looked at the sparkplug wire and it's fine. I have a new opti and new SVO injectors. A friend of mine shot a heat gun on that sides header before I replaced the header gasket and it was running about 100 degrees cooler (320 degrees). I'm hoping the new gasket fixed this problem but I don't have the heat gun to check. I don't think it's a problem with my new tune because it's only affecting 1 sparkplug. The rest of the sparkplugs look clean but the #6 is really black.
RX Speed Works
Sep 11, 2015 03:31 PM
RX Speed Works
Jul 24, 2015 02:25 PM
