Fouled plugs in 100 miles, cause?
Old Jan 2, 2008 | 01:17 PM
  #16
speed_demon24's Avatar
Update... Changed the plugs and they didn't help it at all. The car runs perfect at part throttle and cruising. There is no popping or missing and it also doesn't miss at any RPM at part throttle. I took it up to 6K at 50% throttle and it never missed a beat. I guess I'll try an ignition box next.
Old Jan 2, 2008 | 01:22 PM
  #17
SS MPSTR's Avatar
Are you OBDI or OBDII? I think you answered before, but I forgot.
Old Jan 2, 2008 | 01:25 PM
  #18
Wild1's Avatar
You mentioned that the NGK TR6s are a 1/2 heat range hotter than the TR55s... are you sure?
NGK says that the TR6 is actually colder than a TR55.
Your plugs seem to be a rich condition. They don't look oily to me.
Old Jan 2, 2008 | 01:42 PM
  #19
I said the autolite 104's are supposidly 1/2 heat range hotter than the tr6's. I know the tr6's are a heat range colder than the tr55's, thats why I'm running them.
Old Jan 2, 2008 | 01:45 PM
  #20
OBDII. My tuner said he couldn't think of any real advantage to switching to OBDI since they both have their advantages and disadvantages. It never did this with any of my other h/c combo's so I don't think its a PCM issue.
Old Jan 2, 2008 | 02:04 PM
  #21
SS MPSTR's Avatar
Two other CA guys (not including myself) switched to OBDI and ridded ourselves of the dreaded miss.
Old Jan 2, 2008 | 02:29 PM
  #22
Did you guys have the same symptoms? And whats involved in an OBDI switch? I've never really researched it, all I know is you need an obdI pcm and an obd1 knock sensor. Can you load the same tune into an obd1 pcm, or do you have to start from scratch?
Old Jan 2, 2008 | 02:33 PM
  #23
SS MPSTR's Avatar
Similar symptoms. I had Jeff Creech load my tune into my OBDI PCM. Other than switching the PCM and KS (which I understand you don't even need to do that anymore with some circuit soldering), the switch is fairly painless.
Old Jan 2, 2008 | 02:40 PM
  #24
Thanks, I'll keep my eye out for OBDI pcm's for sale.
Old Jan 2, 2008 | 03:20 PM
  #25
LT4 Formula's Avatar
Yeah I know it looks like its from running rich, I'm hoping it was from a bad 02 sensor. My tuner tried taking out fuel and adding it at part throttle and where it was was pretty much the best spot. The A/F was ~ 14.6-15.0 when the car was idling on the dyno if that helps.
How much overlap on the cam? Could play havoc with your o2's.
Old Jan 2, 2008 | 03:32 PM
  #26
02's have nothing to do with WOT performance.
Old Jan 2, 2008 | 04:15 PM
  #27
Yup, but they do at idle. So unless you have zero time idling...
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Jason Short
Jan 19, 2015 06:34 PM
kev93z28
Aug 19, 2002 12:48 AM
funina91ss
Aug 6, 2002 11:20 PM
