Formula overheating
Old Mar 3, 2008 | 11:30 PM
C93camaro's Avatar
Formula overheating
I've got a 1996 Formula and it seems to overheat on me. When im traveling down the road the temp. is fine, i'd say about 185 and when it sits and idles it runs over 210 and keeps going up and it will drop back a little and then go back up and back and forth it goes. I've replaced the thermostat. Fan's work fine, doesn't have a head gasket leak. And i have an infered laser and it say's that heads are at 185-190 and i check the radiator not to hot. I'm running out of idea's, could it be a bad gauge...Any other idea's would be greatly appreciated. Thanks
Old Mar 3, 2008 | 11:45 PM
1997whitez28's Avatar
Hey
Got the same problem. I did my temp sensor on the block 3 hours ago. So far so good. Also do the sensor in front of the water pump. Bleed the coolant, while your there change it.
Old Mar 3, 2008 | 11:47 PM
Doesn't sound like you have a problem. When you stop, so does air flow across the radiator. The engine heats ups and the fans come on when the ON temp threshold is met. The engine cools and fans go off. The cycle repeats if you stay still.
Old Mar 4, 2008 | 07:03 AM
2000GTP's Avatar
Keep in mind too that these cars do run warm from the factory, it does sound like normal operation.
Old Mar 4, 2008 | 07:23 AM
ss.slp.ls1's Avatar
Sounds normal, at idle your car will fluctuate back and forth from about ~200 - 226.
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
damnyankee36
Sep 9, 2015 07:06 PM
Pwilson59
Sep 3, 2015 08:47 PM
