Forged pistons and Rods
If you're on a budget check this out....
http://store.summitracing.com/egnsea...s=false&N=+115
Kit has Pistons and all the gaskets you'll need HOWEVER you need to figure out how much the block needs to bored AND what type of rods you are using BEFORE you order. They don't do refunds on this stuff so make sure you get it right the first time, each kit is made to order. Those pistons will handle nitrous, get some good rods like some H Beams for about $200-250. I'd also suggest some head studs too if you're going to spray the **** out of the motor.
You should've titled this thread BUDGET 355, I see people trying to tell to you get forged cranks and stuff hahaha.
If you want further info on that kit search for "summit rebuild kit" in the LT1 section on here, quite a few people have used it with a good bit of success....also searching for "budget 355" will yeild more results in the way of what your looking for.
RUENUF
Mar 13, 2016 03:37 PM
Catmaigne
Jul 14, 2015 05:17 PM
