Forged 383 parts ?s
Old Aug 18, 2004 | 06:20 AM
TQdrivenws6's Avatar
Forged 383 parts ?s
Hey everyone,
I am putting together a forged 383 setup currently, and here are my goals for the project. I want it to be a stout motor N/A, but be able to handle a decent sized shot of N2O when that time comes. The heads and cam are set, so I just need the rotating assembly. I would prefer to keep a compression ratio somewhere around 11:1.
As far as components, I was looking at the following, but none are set in stone:
Eagle ESP 6.000" H-beam connecting rods with L19 bolt option
Eagle Forged crank
Clevite 77 main, rod, and cam bearings
Total seal gapless TS1 rings
As far as pistons, I am having trouble finding something that will take a floating pin, on a 6" rod, and have a static compression ratio in the area of 11:1. The biggest requirement is that it needs to stand up to a moderate shot of juice.
Thanks,
Chris
Old Aug 20, 2004 | 01:33 AM
slp223's Avatar
Re: Forged 383 parts ?s
if you find a kit you can save some money i have a callies with eagle rods and je piston i got if 2 years ago for 2000 out the door i dont know how price are now but at the time it was much cheaper then parting it all togerher.
Old Aug 20, 2004 | 06:19 AM
Well, I ended up ordering a 'kit' from combination motorsports. It should be here by the end of next week. I got the following in the kit:
Eagle forged 3.75" crank
Forged Eagle H-Beam ESP rods with the L19 rod bolt upgrade.
SRP -16cc pistons, floating pin
Clevite 77H bearings
SRP ring kit
The engine will be out soon, and then the disassembly begins.
D1SC383LT4
Jan 26, 2015 01:41 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
97 RedSS
Jun 10, 2003 07:58 PM
