Flushing the rad
Old May 18, 2003 | 11:49 AM
SloMofo's Avatar
Question Flushing the rad
It's time to flush my rad again, but I forget how much coolant/water to put in.
Anyone know?
TIA
Old May 18, 2003 | 11:54 AM
snakeatinZ's Avatar
me personally I would roll about 30% coolant and 70% water in the summer time, nothing cools beter that good old h2o. in winter I put a 50-50 mixtuer. dont forget the 160 stat!
Old May 18, 2003 | 12:12 PM
SloMofo's Avatar
Already have a 160* t-stat
Anyone know how many Qts to put in?
Old May 18, 2003 | 12:21 PM
chasmanz28's Avatar
15 quarts
Old May 18, 2003 | 12:23 PM
Sam95ZNoTop's Avatar
If eveything is empty including the block, it should hold 15 qts. I found out last weekend that the block holds about 2 gallons ( I wasn't able to get the block drain plugs out)
HTH
Sam
Old May 18, 2003 | 12:27 PM
madwolf's Avatar
Yes, as mentioned above, chances are that you won't be able to drain all the coolant and so you won't need 15 quarts. I'd recommend getting some distilled water and have a few extra quarts as a backup because it may take a little more fluid to get all the crap out.
If *I* were to do it, I'd just take the radiator out and do it right.
Old May 18, 2003 | 02:19 PM
SloMofo's Avatar
HTH
Sam
I will only be flushing the rad not the block. How many qts for that?
Old May 18, 2003 | 07:10 PM
Assuming every hose is drained just short of 2 gallons (15qts - 2 gal)
Old May 18, 2003 | 08:47 PM
thewinner's Avatar
15 qts is not 2 gallons....
Old May 18, 2003 | 08:49 PM
madwolf's Avatar
That was 15 quarts minus 2 gallons = 7 quarts.
Old May 18, 2003 | 09:05 PM
thewinner's Avatar
gotcha now.
Ion, can you take a look at my TPS and MAP post and check the datamaster file out and see if you can determine wtf is going on with these 2 sensors?
reww86
Aug 29, 2015 06:04 PM
Noct
Jul 14, 2015 01:18 AM
kksi
Feb 17, 2015 10:41 PM
carcrazyQT
3rd Gen / L98 Engine Tech
Aug 10, 2002 04:35 PM
Geezer
Jul 3, 2002 05:16 PM
