Flush radiator
Old Sep 19, 2004 | 03:22 PM
Purplemaroz28's Avatar
Flush radiator
Guys i need to flush my radiator out, so should i pull the hose or is there a plug that would be easier/better than pulling the bottom hose off.
~lemos kid~
Old Sep 19, 2004 | 03:33 PM
MarkyMark's Avatar
Re: Flush radiator
yea there is a little thing to turn at the bottom of the radiator.....no need to take any hoses off.
Old Sep 19, 2004 | 03:44 PM
Re: Flush radiator
thanks
Old Sep 19, 2004 | 06:46 PM
moparman's Avatar
Re: Flush radiator
It's on the lower right hand corner. Beneath the lower hose. Careful you don't break the plastic valve.
Old Sep 20, 2004 | 09:43 AM
ShawnMacAnanny's Avatar
Re: Flush radiator
http://shbox.com/1/drain_valve.jpg
If you turn the steering wheel all the way to the left you can get to it easier. I had to use pliers to loosen mine, but i put it back on hand tight. It is on the passenger side and can be seen by just laying on the ground and looking at the bottom of the radiator.
If you flush it, be sure so flush where the thermostat goes, the overflow resivoir (this was the dirtiest, you will have to remove the hose connected to the radiator and let it hang down), and i let the host flwo through for about a half hour in the radiator.
If you haven't bypassed your TB yet i would do that too. You can get a kit on Ebay for $7. I noticed a huge difference with that and my Hypertech 160.
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
68camaroboltz
Oct 5, 2015 01:46 PM
Pwilson59
Sep 3, 2015 08:47 PM
