flp headers #5 spark plug
Old Mar 29, 2003 | 06:07 PM
akafred's Avatar
how do i get the # 5 spark plug in i have spent 3+ hours on the one plug there is no room for it. soon i will be telling people man i got one mean 7 cylender camaro...
Old Mar 29, 2003 | 06:34 PM
EviLBoX's Avatar
Are you having a hard time tightening it or getting it in the hole? To tighten it, I'd try a standard wrench. That plug went in pretty easy for me, of course I did have the header unbolted when I did it.
Old Mar 29, 2003 | 07:14 PM
akafred's Avatar
im having problems getting it in the hole not tightening it
Old Mar 29, 2003 | 07:36 PM
gb95zconv's Avatar
I can get that one from the bottom pretty easily.I use the SLP cut off plug socket and one of those 3/4 " ratcheting wrenches(I love these wrenches). Start it by hand with the cut off socket then tighten it with the wrench.
Old Mar 29, 2003 | 08:42 PM
akafred's Avatar
cool i will cut a plug socket tommorow and try that thanks
Old Mar 30, 2003 | 08:52 AM
gb95zconv's Avatar
The socket also needs to be drilled out so that it will slip onto the plug. It want be easy to do at home without a drill press and a cpouple of good bits.
Old Mar 30, 2003 | 09:51 AM
T/A#4's Avatar
Thumbs up
I'M TOLD THAT THE HOT TICKET TO THE SPARK PLUG ISSUE IS; REMOVE YOUR FRONT WHEELS, DRILL A 3/16 HOLE THRU THE FENDER WELL TO GET THE CENTERLINE OF THE PLUGS LINED UP, THEN USE A 1 1/4 DIA. HOLE SAW TO CUT A ACESS HOLE. RUBBER TYPE PLUGS ARE AROUND WHICH WILL SEAL THE HOLES. I'M ON THE HUNT FOR A SOURCE OF THESE PLUGS. ANYONE ELSE TRIED THIS ?
Old Mar 30, 2003 | 10:18 AM
Smokn '94 Z's Avatar
Lightbulb Re: flp headers #5 spark plug
Did you get it? If not you can unscrew the end of the plug for a bit more room. I chose to get some accel shorties. It is tight. Wait till you see how close the boots will be to the primaries. Next time I do my plugs & wires I think it will take less time if I just unbolt my headers to back them off a bit to do them.
Good Luck
Old Mar 30, 2003 | 10:39 AM
akafred's Avatar
i got a lathe so making the socket wont be a problem im going to give it a try right now
Old Mar 30, 2003 | 05:38 PM
akafred's Avatar
so i finaly just took the header off to get the plug in fun fun i hope i dont have to change those plats soon
Old Mar 30, 2003 | 05:42 PM
akafred's Avatar
plus the pipe after the offroad pipe hits the frame how do i fix that?
Old Mar 30, 2003 | 05:53 PM
96SilverZ28's Avatar
i have that exact same problem with my flp's with the pipe hitting the frame. unfortunately mine also leak because they didnt weld them correctly. so what i finally did is i just ate the cost and bought some MACs. as far as if i were to keep the headers i was told that you can take it into a good shop and they can dimple the pipe and cut some of that frame out and it wont hit anymore. that was just too much effort/money for me. good luck.
Jared
Old Apr 2, 2003 | 10:41 PM
akafred's Avatar
has anybody tried poly engine mounts to solve the banging prob i dimpled the pipe now i have 1/2" clearance its just hits harder now but not as soon lol what are the down falls of poly mounts thanks
Old Apr 3, 2003 | 03:11 AM
97 WS6 T/A Conv's Avatar
Interesting you mention this. When we did my FLP's we also installed ES motor mounts at the same time and I never encountered the banging problem. hmmm. Then when I did the heads and cam we didn't need to unbolt the mounts and raise the engine for clearance to remove the headers.
As for #5 I used the special plug socket that one of our CZ members fabricated about a year ago. Nice handy little tool. That socket and a 5/8" wrench and it came right out from the top. The toughest part was getting the plug to thread back into the head.
Old Apr 3, 2003 | 06:10 PM
akafred's Avatar
any body else try poly mounts????
