Flip Up headlight Stopped Flipping?
Well I finally got around to the headlight, it was last on my list after the clutch, shifter, etc. I opened the motor up and guess what, the gears are perfect. So, I plugged it into the working headlights power and the motor spun just fine. There is no power to the passenger side headlight motor and this leads me to believe that the relay is bad?!? If so, which relay is it, I cant figure out wich one it is, and what kind of relay do I need to buy to replace it? I would rather not buy one from a dealer. Thanks guys.
In case you dont feel like reading the other posts, my low beams and high beams work just fine. Strangely, the working headlight (driver side) comes up when I turn the switch to the parking light position.
Ok. I did a search and found the control module. I metered the fuses and the working headlight has 9.4 volts at the fuse, while the non-working headlight has 3.4 volts. Does this sound like a bad control module to you?
Henson071
Dec 30, 2015 09:55 PM
Aug 17, 2015 09:50 AM
Aug 5, 2015 08:35 AM
Henson071
Aug 4, 2015 09:32 AM
