fitment issues with air on pacsetter lt
Old Sep 7, 2006 | 04:36 PM
ztwenty8's Avatar
so i did some searching and really coulnt find a good answer
i installed my pacesetter lt's and everything seemed fine, even the egr.
now trying to get my air back in seems to be a different story. now it looks like the hoses will not fit like they used to, so it looks like im going to re-route those lines.
so basically my question is, has this happened to anyone else, and if so does anyone have pics how they modified it?
thanks in advance
mike
Old Sep 7, 2006 | 05:13 PM
calfirebird's Avatar
Re: fitment issues with air on pacsetter lt
i put 2 oil drain plugs from a dodge diesel in mine.
Old Sep 7, 2006 | 05:41 PM
Disifer's Avatar
Got caps from home depot.
Old Sep 7, 2006 | 06:48 PM
salty's Avatar
I torqued the fittings in with a pipe wrench before the headers were in the car. Really rounded the nut off, though. Not actually recommending this, but it worked for me. I don't think I couldv'e done it with the headers attached to the car.
As far as the rubber hose is concerned, my air system is still hooked up-so I bought longer hose. The stock hose wouldn't reach.
Old Sep 8, 2006 | 03:45 PM
ztwenty8's Avatar
i do have emissions in my area, so i kinda prefer to use the air and egr stuff
Old Sep 8, 2006 | 07:40 PM
Severous01's Avatar
i can't find a pipe fitting that will fit. it's a 22mm fitting. nobody sells one that swaps over to the 1.25" AN.
i can find the 1/25" and i can find 22mm, but i can't find one that goes to the other....that's what's needed. right now i have a loose fitting in there just to make the connection and it's sealed with a 1.25-1.25 AN addapter...it's not fitting into the header but fits into the AIR elbow. i'm thinking of capping it off if i can't get it fixed right.
calaban
May 18, 2020 06:43 PM
David Dorris
Jan 17, 2015 08:10 PM
95chwagon
Jan 13, 2015 09:19 PM
ddr698
Jan 9, 2015 10:05 AM
cmdeshon
Jan 4, 2015 11:15 AM
