First time to the track w/ the new car
Old May 6, 2005 | 08:38 PM
89385formula's Avatar
Well, I decided to test out the new car since the clutch is finally broke in. Our local track is a 1/8 mile, and tonight was test and tune night. I had a serious case of stage fright because there was alot of people there. I ran w/ the 17's on instead of throwing the DR's on as well so I didn' expect anything great. my 60 FT was horrible at a 2.6...I spun very bad and the launch was also weak. I ended up breaking something in the top end on the 2-3 shift and still managed a 8.91 @81.39. I even shifted early too. Are these ok numbers? I know they could be alot better w/ some DR's and without breaking the damn thing. What do you guys think tho?
Old May 6, 2005 | 09:49 PM
MEAN LT1's Avatar
Re: First time to the track w/ the new car
Yea, your times should be way better than those. What hurt you was your 60'. IF you can get that down to a 2.1 or below you'll see a dramatic decrease in et and more mph. You also might want to think abouyt some gear as well.
Old May 6, 2005 | 10:14 PM
Yeah, I know the 60ft was horrible. I think my trap would have been a good bit higher as well if I hadn't broke whatever I broke on the 2-3 shift. I pulled pretty slow after the shift. Like I said this is the first time out with the new car, and i didn't expect to do great...although I was hoping that nothing would break....so much for that!! I probably won't bother with gears until I do a new rear. Tonight was kinda just a base run to get to know the car. I have a nitrous kit that I will be installing soon once i get whatever broke fixed. BTW I have 3.42's now anyways, so its not horrible. If I get it fixed by next friday, and get the SFC's welded in, I will throw the DR's on and let you know if I do any better.
Feffman
Oct 9, 2015 05:42 AM
Louey
Pacific
Dec 25, 2014 03:27 AM
Louey
Pacific
Dec 8, 2014 08:01 PM
Louey
Pacific
Dec 1, 2014 04:16 PM
USAirman93
Nov 24, 2014 03:37 PM
