First time ever at track.
Old Jul 30, 2003 | 10:35 PM
FIREHAWK_21's Avatar
Are these times any good? I know I need some practice.
60' 2.307
1/4 14.19
MPH 100.24
95 FireHawk. K&N, Lakewood control arms, HPP3, TB bypass. 6spd. I'm either fryin the tires on the launch or not getting out of the hole hard enough I can't get nothing in between.
Old Jul 30, 2003 | 10:41 PM
ZYALATER's Avatar
Not bad. Get that 60' time down and your et will drop.
People say for every .1 off of your 60' equals .2 off your 1/4 et.
Practice makes perfect.
Which track did you run at?
Brettinator's Avatar
Re: First time ever at track.
60' 2.307
1/4 14.19
MPH 100.24
Not bad. I'd say your 60' needs some work and something like Nitto 555's at the track wold shave a good 2-3/10ths easily. On slow tree launch right on the 3rd yellow, try not to stage too deep either. Your car will respond well with a few mods like longtubes and catback of some sort, Corsa, Borla or something good. Good luck.
Old Jul 30, 2003 | 10:45 PM
jasons93z's Avatar
you should be low to mid 13's if you launch better
Old Jul 31, 2003 | 07:20 AM
It has the SLP Drivers Side Exit cat back with 3" pipe and 2 1/2" y-pipe, but I still have the original tires on the car and they're pushin 9yrs. I think I'll do alot better with a stickier tire and a little practice. I'll probably get headers and gears in the near future. I want to get 13.40's with these mods.
Muncie Dragway is where I ran.
Old Jul 31, 2003 | 08:09 AM
TedH's Avatar
Drag radials and practice. It takes more than one day to become John Force.
Old Jul 31, 2003 | 11:23 AM
chesee48's Avatar
Ya that 60ft is what i cut when i went stock. Its sick. And the Stock tires at the track will KILL your times...use DR's and your easily in the 13's...
Old Jul 31, 2003 | 11:35 AM
SloMofo's Avatar
Get that 60' down and you should be good to go
Old Jul 31, 2003 | 05:00 PM
I have t-tops should I put on frame ties before drag radials or will I be ok if I'm not adding any power?
Old Jul 31, 2003 | 05:10 PM
jasons93z's Avatar
It wouldnt hurt, but your not gonna crack your t-tops or anything right now.
Feffman
Oct 9, 2015 05:42 AM
ChrisFrez
Feb 1, 2015 08:26 AM
BMP Mike
Jan 7, 2015 11:12 AM
Ken S
Jul 25, 2002 11:23 PM
