firebird clear corners
Old Mar 22, 2003 | 09:47 PM
rob96TA's Avatar
I want to try to make clear corners for my 96 trans am, but want to know if anyone here has tried doing this before without damaging the yellow lens. Can it be removed without breaking?
thanks.
Old Mar 22, 2003 | 09:48 PM
RamAir95TA's Avatar
Yes you can, but you need to be VERY careful. It will easily shatter if you apply too much pressure. I removed one side unscathed, the other completely shattered.
Old Mar 22, 2003 | 10:03 PM
rob96TA's Avatar
thanks, but did you use a heat gun to losen up some of the glue?
Not to sure if that's even glue, or just the 2 plastics melted together.
Old Mar 23, 2003 | 10:35 AM
97FormulaWS-6's Avatar
Well.. actually I didn't need to heat mine, just ran through the seam with a utility knife and it basically pulled apart. I had to grind some of the old yellow oarts off that were left behind but nothing major. THen I had to modify the insides a littlebit because one part will interfear with the new clear lenx.. you'll figure it out once you get in there. I also put a coat of chrome spray-paint inside mine because a lot of the reflective coating was gone. I then used a bunch of rubberbands and some Goo-Glue to glue the new lens on and some clear RTV around the ourside just as insurance once the glue dried. Mine turned out really good, and I've had no issues with them at all.
Old Mar 23, 2003 | 10:41 AM
rob96TA's Avatar
thanks for the reply.
I heard that the lens's melt from the bulb. Is this true.
97FormulaWS-6: Do you have any pictures of your clear corners? i checked your cardomain site and couldn't find any
Old Mar 23, 2003 | 11:43 AM
RamAir95TA's Avatar
I never had any problems from the lens melting.
I used the same method that 97FormulaWS-6 used. I love them.
SpeedJunkee
Jul 19, 2015 09:06 PM
Latronaxe
Jul 17, 2015 11:55 AM
Noct
Jul 14, 2015 01:18 AM
RamAir95TA
Jul 21, 2002 12:17 AM
