LT1 Scanmaster code ?
16 - OptiSpark low resolution pulse not found
41 - Ignition control circuit, open
51 - EEPROM program error
Was it raining or did you take your car to a carwash prior to these codes?
My car and a friends car will throw these codes 'Sometimes' if It rains heavily or on 'certain' car wash places that we go to. I usually just pull the PCM fuse for 5 minutes to clear the codes and its usually fine. Try re-setting the PCM, put the fuse back in it and see if the codes dissapear.
Hope that helps,
Hope that helps,
PS...Forgot to mention
You can find what all the codes mean on this page:
http://members.aol.com/InjuneerZZ/ScanMast.htm
(the codes are listed towards the bottom of page)
Thanks,
Claude
Thanks,
Claude
