Finish LS1 brakes, think i have a air leak, need help
After spending 2 1/2 hours bleeding the system I have found that i got all the air out of my rear brakes (I didnt not change them or remove the lines). But i cant get air out of the front brakes. There is a lot of air in teh front brakes... not like air bubbles but air.
Now the master cylinder has two chambers in it right? 1 for the front and one of the back brakes. I had let the front run dry. I tried bleeding the ABS modulator but i kept getting air there to... I think it might have been a fitting on the mity vac that wasnt working properly when i was bleeding it..
But if i cant get all the air out of the front brakes would i have enough braking power from my rears to get me to a shop?
Brake_L8
Jan 20, 2015 09:44 AM
95chwagon
Jan 13, 2015 09:19 PM
