Finally , ordering a Cam
Ok guys after all my BS talking about what cam i want and asking dumb questions im finally about 5 minutes away from ordering a cam.
My car is mostly stock besides the mods in sig
I plan on getting the CC 503 224/230 .503/.510 (stock 1.5 rockers)
also i am ordering 1.6rrs (later on) which would make my lift .536/.544
so with the lift at .536/.544 what springs do u recomend , also what brand rockers/stud size, also should i order SA or Non-SA rockers
lifters and pushrods should be fine? (the car has about 77k on it)
also i plan on a 25-2800 stall
thanks guys
bobbyd
thanks guys
bobbyd
Re: Finally , ordering a Cam
I have an entire spring setup by crane cams. Good to a .600 Lift. Brand new installed but never used(youll see proof when you get them) Comes with springs, locks,retainers and spring seats to be able to fit on stock heads with no modifications. 150$ plus shipping. Let me know-Mark
I will be installing the following on Saturday:
Comp Cams XE 224/230 .536/.544
Comp Cams Pro Magnum 1.6 Non self aligning 7/16" roller rockers
Comp Cams 26918-16 Beehive springs
Comp Cams 4705-16 Spring seats
Comp Cams 614-16 10* locks
Comp Cams 795-16 Retainers
Comp Cams 3136 Double roller timing set (requires electric water pump conversion), 96-97 must switch to a 93-95 crank hub
GM #14011051 guideplates (8 qty).
Also, for the stall go 3000 or higher. I got a 3200 and wouldn't mind something bigger.
It's really not bad around town....I'd take a stall over a stocker any day for daily driving.
the 503 wasnt one of my main choices, i only decide to go with it b/c its a very popular and and my buddy has it and has no complaints about it.
ive never heard bad things about the cc 503,
another thing i dont plan on running a stall any larger than a 2800 so that would also effect my choice.(dont ask y lol)
i figured the 503 will best suit what i want for my car at the moment.
also is a gear change completly necessary im an A4 (3.23s)?
i still havent ordered the cam do to problems with my Card but it will be straightened out b4 the end of the week.
camr0z28 how much did the cam plus all valvetrain parts end up costing in the end just looking for prices
ARP 7/16" studs
Valve Seals
and all gaskets for the swap
ARP 7/16" studs
Valve Seals
i got the exact same valvetrain off JnJ except without the timing chain and with 7/16" studs and all gaskets for the swap for $656.88 (after tax)
So along with my question on whether i should change lifters and push rods and also if my stock gears would be good for now, should i go with SA or Non-SA
im prolly gonna go with the same settup as cmroz28
stall will come later
with tuning
hoep i like it, which i have no doubts i will
i really really hope the weather turns i so want to do some install work by myself (with others that actually know what they are doing lol)
sorry for all the questions but will a stock replacement timing chain be ok , i really dont want to dish out the money for the double roller and the E-WP at the moment
not needed.... but..... i know im kicking myself for not dropping the extra money and doing it while i was in there.
and ill stay away during the install... prob be cheaper that way
i got my new card, ordered the cam today , valvetrain will be order when i get my check this week ,
with tuning
with tuning
I would definatly reccomend gears. i had 3.23's also, and it pulls much much better (definatly feel the difference) with 3.73's. If I could go back, I'd probably want a bigger stall too(i have a 2800)...i'd take a 3200 - 3400. But even with the combo i have now, its hard to get any traction, even with drag radials.
Forget the 2800 stall, go with a 3200. You're not going to see any drop in driveablity.
IMO 3.73's are a must for this cam at some point, really wakes the car up and picks up MPH on the big end.
The cc503 is an excellent choice for a stock head car, you won't be disappointed.
As far as supporting components, cmr0z28 gave you the correct list to go by.
I don't know how much the exact total was...I got everything from Bret Bauer (SStrokerAce) but didn't buy it all at once, and I got the rocker arms used off of another guy on this board.
I got Comp Magnum pushrods for $93, Comp timing set, Beehives, locks, retainers, seats for I think $400 shipped, cam was $235ish on sale from Texas-Speed, plus the opti, etc.
Oh, and 7/16" rocker studs were $40...re-using my stock lifters. I can't remember if I bought anything else. I'll have to look in my pile when I get home.
Oh, and GM guideplates were like $25 for 8 from the local dealer. Prepare to spend about $100-125 in gaskets, fluids, RTV, loctite, etc unless you already have some of it.
Hope this helps,
Hope this helps,
