Finally got some track #'s. LE3 383 VIDEO!
Old Sep 16, 2007 | 10:00 PM
Josh'95Z28conv's Avatar
Finally got out to the track today. It was hot. Mid 90's, and humid as always in south Texas. I have a nasty sunburn on my neck and face
Dyno #'s in sig.
Best et:
1.74 60ft
7.65 1/8
92.1 1/8
11.93 1/4
116.37 1/4
Best trap:
1.85 60ft
7.74 1/8
92.98 1/8
11.94 1/4
118.48 1/4
Not a bad day. I went out on the 4th round- red light Ran fairly consistant, and I dont think my 60's are too bad for a manual. It has more in it too. On the dyno it dropped off sharply at 6600 rpm. I think my valve lash is a little on the tight side with the morels. If I loosen them up I could get a couple hundred more rpm and a little higher mph.
Not too bad for a 3700lb LT1?
Video: http://videos.camaroz28.com/video/57...ab017c8e0c.htm
Old Sep 16, 2007 | 10:15 PM
reamo04's Avatar
definately time for ya to get some suspension
Old Sep 16, 2007 | 10:22 PM
Such as?
Old Sep 16, 2007 | 10:39 PM
reamo04's Avatar
Originally Posted by Josh'95Z28conv
Such as?
torque arm, relocation brackets, adjustable LCAs, sway bar, etc.
did you have drag radials on there or what?
Old Sep 16, 2007 | 10:52 PM
I do have drag radials. I also have sub frame connectors. I know I need some other suspension stuff too, but that will come very slowly in the future. I know I need a good TA, an adjustable panhard bar, and LCA's. Is it good to put on a bigger rear sway bar?
Old Sep 16, 2007 | 11:07 PM
reamo04's Avatar
yes, a bigger sway bar should help level out your car for your launch IIRC. it will help with keeping your car straight on launches, eliminate torque steer, and body roll
Old Sep 16, 2007 | 11:18 PM
Z-RATED94's Avatar
Do you at least have an air bag on the right rear for now? It does help a little, and is fairly cheap.
Old Sep 16, 2007 | 11:58 PM
bombebomb's Avatar
+1 on this post, with some suspension ull cut quite a bit of time off. I don't know how your running that much power without more suspention mods.
Old Sep 17, 2007 | 12:00 AM
If I do suspension mods and lower my 60' more Ill probably break the 10 bolt. Oh well, thats on my wish list too
Old Sep 17, 2007 | 02:45 AM
solarofthesix
Guest
Posts: n/a
LCAs will prolyl save your rear for a bit as they eliminate wheel hop
Old Sep 17, 2007 | 07:07 AM
I dont have wheel hop
Old Sep 17, 2007 | 07:39 AM
camaro81's Avatar
Just get the rear end girdle and start praying
Old Sep 17, 2007 | 08:11 AM
Bersaglieri's Avatar
Great numbers both dyno and track. Knock a few off that 60' and you're looking at some mid 11's no problems. When are you going to start squeezing it?
-Dustin-
Old Sep 17, 2007 | 09:17 AM
Javier97Z28's Avatar
Moderator
Great results for 90* weather, nice to see another car performing well... heavy car too bein a vert.
You'll get 120+ traps with no problems in good weather and some tweaking here and there.
Good job.
Old Sep 17, 2007 | 01:53 PM
jammer94's Avatar
heavy car is my 4500 lb roadmaster w/o me in it geesshhh
