Finally got some times
Old Jul 15, 2003 | 05:33 PM
Sweetred95ta's Avatar
I just had the hotcam kit put in my car not too long ago. I had a little head work done (stage 1 & bigger valves), and some other stuff put on (see sig). Well, i was wonderin if a 12.85 @ 108.4 (cutout open) is a good starting point? I am having it dyno tuned and i wasnt sure if i am running as quick as i can or i should have it dyno tuned to find the xtra ponies. I know i need a converter, and it is coming, but is a 12.85 @ 108.4 a good time for a converterless lt1 with the hotcam kit? And, i cant run anything less than a 13.0 with that damn cutout closed, is this normal too? I appreciatte all the feed back.
Benji
Old Jul 15, 2003 | 06:30 PM
Smokn '94 Z's Avatar
Lightbulb
Sounds real good without a converter. Put in a Vig 3200 & you may flirt with the 11's. Very nice.
Old Jul 15, 2003 | 06:32 PM
bad95z28's Avatar
ditto... should be very very low 12s with a convertor and good tuning. maybe even high 11s. apparently those heads are pretty decent.
Old Jul 15, 2003 | 06:45 PM
Thanks guys, that makes me feel good about all the money I spent on my car. So possible 11's, i never dreamed that without spray. That would b bad. In a good way.
Old Jul 15, 2003 | 06:46 PM
White_94_TA's Avatar
Very nice times man. How do you like the shorties?
Old Jul 15, 2003 | 07:03 PM
The edelbrocks? I like them, they give the car a better sound than just the stock manifolds. They're no SLP's or anything, but they get the job done. That is until I go LT. So, 3200 vig? I thought about a 3600 vig. I would probably buy what came along first. Which would be better?
Sergio
Jan 27, 2016 04:27 PM
kandied91z
Jan 23, 2015 11:14 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
ChrisFrez
Dec 7, 2014 06:01 PM
