Finally got my engine built. Pictures!
Old Jun 18, 2005 | 06:30 PM
Silvershark's Avatar
Ok, after 6 months, lots of time and money I finally got the engine complete. I will have pictures by the end of today with the headers installed and the intake on. Hopefully the balancer pully on as well.
Enjoy!
http://www.akgaming.com/~kendall/images/355.jpg
http://www.akgaming.com/~kendall/images/lt1355.jpg
http://www.akgaming.com/~kendall/ima...maro%20012.jpg
http://www.akgaming.com/~kendall/ima...maro%20013.jpg
http://www.akgaming.com/~kendall/ima...maro%20018.jpg
http://www.akgaming.com/~kendall/ima...maro%20025.jpg
http://www.akgaming.com/~kendall/ima...maro%20027.jpg
Old Jun 18, 2005 | 06:41 PM
slverbullet's Avatar
Re: Finally got my engine built. Pictures!
cogratulations! i was there a few months ago, so i know the pain that you were going through! looks good and have fun!
Old Jun 18, 2005 | 06:48 PM
93black-ta's Avatar
hey, your about at the same stage as me webshots
Old Jun 18, 2005 | 06:58 PM
ejfagala's Avatar
Looks great
Old Jun 18, 2005 | 07:02 PM
chevy94c's Avatar
Thumbs up Re: Finally got my engine built. Pictures!
Nice
Old Jun 18, 2005 | 07:42 PM
Thanks for the compliments. Here are a few more pictures. Too much bling, the pictures just dont do it justice. I polished or had everything bead blasted so there is just too much glare.
http://www.akgaming.com/~kendall/ima...maro%20029.jpg
http://www.akgaming.com/~kendall/ima...maro%20038.jpg
Old Jun 18, 2005 | 08:33 PM
1racerdude's Avatar
Niiiiiccccceeeee work.If it runs as good as it looks it will be a winner.
Where did ya get the plug wire holders?
Old Jun 18, 2005 | 10:49 PM
JKDZ28's Avatar
Nice, now get it together and put it in your car!
Old Jun 19, 2005 | 12:59 AM
Loadre's Avatar
haha You DO realize that you put the pass head on the drivers side and the drivers head on the pass side, don't you?
Old Jun 19, 2005 | 01:03 AM
1racerdude's Avatar
They do that so they will wear even
Just a couple of pipe plug changes.
Old Jun 19, 2005 | 01:06 AM
Loadre's Avatar
haha Yeah, Pipe plugs from the back to the front. Reverse flow cooling to the back. Coil assembly from the back pass to the front driver. Coolant temp sensor from the middle pass side to the drivers side. That's about it.
Old Jun 19, 2005 | 01:57 AM
Are you guys serious!??! They are on the wrong side???
Old Jun 19, 2005 | 04:56 AM
luckyou03's Avatar
ya your heads are on backwards, the same thing happend to me when I just recently had my motor rebuilt; luckyly I caught it.
Old Jun 19, 2005 | 05:03 AM
1racerdude's Avatar
Yes they are.
Just change the pipe plugs in reverse of what they are now all the holes are there. Don't forget the temp sender belongs in the drivers side. No big thing,just extra work and ya need the square tool to take the plugs out without rounding them and ya can't get them out and no an extension won't fit and they are TIGHT. Your crossover tube goes in the back.
Old Jun 19, 2005 | 02:28 PM
Wow, well thanks for the info guys. I just took the old stuff off the old heads and put it on the new heads. So the stuff on the actual heads are in the right place, I just need to unbolt them and swap them around?
From looking at the pictures in the webshot gallery I see what you guys are talking about. Luckily I hadn't adjusted the roller rockers yet, or put the spark plugs in etc. Shouldnt be too bad, just unbolt, and rebolt them on.
Being away from a project for 2 months sure throws your thinking off. Thanks for the good catch guys!
