Final Test n Tune for the year
Went to memphis tonight and made a few passes for the last time this year. Was hoping to get in the 10s, but it didnt happen. Best pass looked like this:
60'-1.455
1/8-6.96@97.59
1/4-11.01@120.85
I was in the 11.0s all night, just couldnt get past it. Guess Ill try one more time to get it next year before I put the nitrous on it.
60'-1.455
1/8-6.96@97.59
1/4-11.01@120.85
Rear suspension is a umi chassis mount torque arm, umi lcas and relocation brackets. It also has a bmr extreme drag race sway bar. Shocks and springs are stock. Hoping to get it down a little more when I replace those this winter. Tires are hoosier quick time pros 27x11.5x15.
Should have the video up today or tomorrow.
Nice times. Our final T&T here at MIR is going to be on the 25th, I'm going to make a few passes just to see where I stand before tearing into the car over winter. Oh, BTW, did you have any clearance issues with those tires? I was looking into that exact size for my '95. Thanks.
60'-1.455
1/8-6.96@97.59
1/4-11.01@120.85
60'-1.455
1/8-6.96@97.59
1/4-11.01@120.85
Nice times. What size SR cam is that?
Here ya go
http://www.youtube.com/watch?v=oWyJjTrdzag
Tires fit great. They are on 15x10 pro stars with 7.5 bs. Just a little massaging in the front inner fender area. Cam is 24x/25x duration and 64x/64x lift on a 112. The convertor and cam are set for the spray, it should really come alive then. I had also pulled 4 degrees of timing across the midrange for driveabilty and didnt put it back in before the passes. I dont know if it wouldve mattered or not.
Thanks man. I seen your car but didnt get to see any runs. Howd you do? I post as Paul95z28 on MRS,you shouldve came up and said hi.
