Filled Block
Old Nov 20, 2005 | 06:37 PM
Black Cloud's Avatar
Filled Block
If you fill any SBC block can you run LT1 heads?
Race only.
Old Nov 20, 2005 | 07:05 PM
SStrokerAce's Avatar
Re: Filled Block
I guess if your not running any coolant in it you could bolt them on a block and they would work.
Bret
Old Nov 21, 2005 | 12:05 AM
Re: Filled Block
Bret
Thanks,Man
Old Nov 22, 2005 | 01:28 AM
Re: Filled Block
Nobody knows for sure?
You guys are surprising me.
John
Old Nov 22, 2005 | 01:53 AM
Re: Filled Block
I have a LT block filled up to the bottom of the water passage right now. A SBC head would work on a LT motor if you didnt run any coolant thru the motor, so it should work the other way. The oil drainback might be the only issues to look at....
Bret
F'n1996Z28SS
Aug 23, 2023 11:19 PM
LETZRIDE
Outside of United States
Jul 9, 2015 07:17 AM
ad356
Apr 11, 2015 11:12 PM
Sandersen511
Jan 13, 2015 03:49 PM
