filing non file fit rings?
You can regap your rings, but be sure you are measuring them correctly first. Use something like an old piston to square them in the bore an inch down or so (the piston manufactuer will have specific instructions on how they like you to do this) and you need to make sure it is expanded in the bore as much as possible, then get the feeler gauges in there and take a measurement. Make sure you know what youa re doing if you go filing your rings because you will do more harm than good - maybe a lot of harm - if you do a hack job on it and scratch the bore up and make the ends all non square.
NewsBot
Apr 9, 2015 07:10 AM
NewsBot
Apr 8, 2015 06:08 PM
NewsBot
Mar 30, 2015 12:40 PM
NewsBot
Mar 19, 2015 02:24 PM
NewsBot
Mar 16, 2015 12:51 PM
