File Fit Rings?
Old Apr 5, 2005 | 07:31 PM
Kryckter's Avatar
File Fit Rings?
I have some SRP forged pistons and I have tota seal file fit rings.
Bored over .030.
Question is, The instructions say to use the follwoing to gap....
Mild Nitrous
bore x .050 - top ring
bore x .055 - second ring
Being bored out, I come up with
.020
.022
Does this not seem tight for nitrous, or all motor for that fact....
Let me know some opinions on gapping??!?!?
Joseph
Old Apr 5, 2005 | 11:34 PM
SStrokerAce's Avatar
Re: File Fit Rings?
Sounds about right for N2O....
What's it say on NA applications? Don't have the sheet next to me at home.
Bret
Old Apr 5, 2005 | 11:42 PM
Kryckter's Avatar
Re: File Fit Rings?
Shows
.045
.050
For NA "High Performance"
Nitrous only....
.070
.065
So .020 and .022
Any tips file fitting rings?
Built several motors, This will be a first at file fitting...
Do you have to file fit the oil rings also?
Joseph
Old Apr 6, 2005 | 12:06 AM
Re: File Fit Rings?
So going from .018 to .020 for N2O..... I would stick with the N2O gap then.
Usually instructions will say what needs to be done to the oil rings.... I always check them because I've had one grab and screw up a hone job.... but for the most part they say don't touch them in the instructions.
Bret
Old Apr 6, 2005 | 09:26 AM
Kryckter's Avatar
Re: File Fit Rings?
Thanks for all the help
Old Apr 6, 2005 | 04:18 PM
WS Sick's Avatar
Re: File Fit Rings?
I allways keep the ring square while filing (if you dont have a fancy tool) and remove burs from the edges when complete.
Old Apr 10, 2005 | 08:25 AM
arnie's Avatar
Re: File Fit Rings?
Bored over .030.
Mild Nitrous
.020
.022
Shows
.045
.050
Nitrous only....
.070
.065
So .020 and .022
I'm clueless here. Don't know if it's me, or the wording. Bret obviously understands, so it must be me. I gather the gapless rings are NOT being used on this one. From initial post, I interpret the recommended gap at .050" on top, and .055" on second, for a nitrous application. It is stated the actual (as received gap) is .020" on top, and .022" on second. A question was asked if that (.020"/.022") were too tight. Then... in second post, the gaps for nitrous application increase to .070"/.065", but staying with .020"/.022". Then Bret states 18/20. I trust my interpretation is incorrect.
NewsBot
Apr 9, 2015 07:10 AM
NewsBot
Apr 8, 2015 06:08 PM
NewsBot
Mar 30, 2015 12:40 PM
NewsBot
Mar 19, 2015 02:24 PM
1963SS
Feb 6, 2015 10:05 AM
