Fiberglass intake elbow?
Old Apr 30, 2006 | 07:26 AM
MeanGreen97Z's Avatar
http://cgi.ebay.com/ebaymotors/LT1-L...61021385QQrdZ1
Good idea.... Has anyone seen who makes these?
Old Apr 30, 2006 | 09:47 AM
dochidalgo's Avatar
Re: Fiberglass intake elbow?
I can't see the MAF sensor and the IAT sensor attached to the albow neither....that makes me wonder is a fake....However the design is similar to the K&N long tube elbow.......
I could be wrong...
dochidalgo
Old Apr 30, 2006 | 10:05 AM
Fbody1's Avatar
what do you mean ? mass air looks like it should mount up ok , and the AIT sensor( if you choose to put it in the stock location) looks like you can drill a small hole and put a grommet there.
Old Apr 30, 2006 | 10:21 AM
Ya the seller commented that you can drill the fiberglass for the IAT but relocating it is easy too. The same seller has a reproduction of what looks like the Moroso CAI with a bigger inlet for the filter. They look like decent pieces..... might be worth checking out.
Old Apr 30, 2006 | 10:43 AM
Honda Hunter's Avatar
Are you sure it will line up correctly with the MAF attached?
Old Apr 30, 2006 | 10:51 AM
Fbody1's Avatar
it looked like there was a pic of it on a car ,but it was a speed density car with no maf, but if it fit's that one it should line up just like a maf car would.
Old Apr 30, 2006 | 01:04 PM
2000GTP's Avatar
Not too terribly expensive and it does look like it will work well with a MAF.
Old Apr 30, 2006 | 01:06 PM
buzz12586's Avatar
Hmmmm, I need a new elbow but I don't know if I am willing to risk that not working. Anyone else tried it yet??
Old Apr 30, 2006 | 01:08 PM
97z28/m6's Avatar
would it not crack?
Old Apr 30, 2006 | 01:54 PM
Fbody1's Avatar
would it not crack?----- No not from the heat, Yeah if you run over it with your car it probably will crack!
Anyone else tried it yet??----- on his ebay feedback a couple of guys bought some a while back and left really good feedback so i guess they work/fit good
Old Apr 30, 2006 | 02:00 PM
I understand it suppose to withstand heat soak alot better than stock but I wonder how much. I wish I could see some real world testing done.
Old Apr 30, 2006 | 02:05 PM
97z28/m6's Avatar
Originally Posted by Fbody1
would it not crack?----- No not from the heat, Yeah if you run over it with your car it probably will crack!:
i mean from the engine moving and it being mounted to the body. the factory one is rubber for a reason.
Old Apr 30, 2006 | 02:08 PM
It's not directly connected. Theres a rubber hose.
Old Apr 30, 2006 | 02:20 PM
Seller told me he only has 2 of these for sale right now and will have 3 more next week. He has plans to mass produce them. It looks like it will work with a MAF for sure.
Old Apr 30, 2006 | 03:32 PM
luckyou03's Avatar
doesn't look like it'd outflow the stocker to me
