feul injectors
Old Feb 2, 2004 | 04:45 PM
ScottZLT1's Avatar
feul injectors
I just purchased a 52mm thorttle body will i need new fuel injectors? I also have an SLP cold air intake and under drive pullies with thoughts of a jet performance chip and headers for sure. Any thoughts would be helpful Thank you
Old Feb 2, 2004 | 04:47 PM
ibanez6rg's Avatar
No, stock will be fine if that's all you've done.
besz28's Avatar
no you will not need bigger injectors. and save your money a don,t buy a jet chip or module. maybe some gears
Old Feb 2, 2004 | 04:51 PM
ScottZLT1's Avatar
PCM
Did your PCM for less computer progaming work well or no. Is it worht it.
Old Feb 2, 2004 | 04:57 PM
ibanez6rg's Avatar
You're picking the apples before you plant the seed.
Old Feb 2, 2004 | 06:31 PM
'94 Bad A Z28's Avatar
LMAO!!! Very true... I am still on stock tuning and I have more done than he has listed.
Old Feb 3, 2004 | 07:53 PM
ScottZLT1's Avatar
what is a good set of headers to go with? The longest last. What is a good gasket set for i won't get any leaks
Old Feb 3, 2004 | 07:58 PM
ibanez6rg's Avatar
Logest last? Do you want shorties, mids, or longtubes?
Old Feb 3, 2004 | 08:47 PM
93Z286Speed's Avatar
if u need to stay emissions legal go with Mid Lenghts... No emissions.. LT's
as for lasting the longest.. basically anything with a good ceramic coating will last prettttttttty darn long
G-BODYT56
Jan 14, 2022 11:14 PM
magman
Apr 15, 2016 03:08 AM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
