Felpro Oil pan gasket
Old Aug 6, 2006 | 05:59 PM
Heatmaker's Avatar
Advanced Member
Anyone know the Felpro p number for the oil pan gasket?
Old Aug 6, 2006 | 06:13 PM
stroked383z28's Avatar
Re: Felpro Oil pan gasket
You can use 1886 or OS34500R. Both are one piece gaskets. I always use the 1886.
Old Aug 6, 2006 | 07:51 PM
1racerdude's Avatar
Little tip,if ya don't want leaks with a Canton run a cork SBC gasket and fill the pan with solvent to check for leaks in/at the welds.
That is if ya are running one. I just ain't had good luck with the silicone gaskets with the crush spacers either Ford or Chevy.
Old Aug 6, 2006 | 10:01 PM
T/A KID's Avatar
1racerdude what is the SBC cork gasket, I have a Milidon pan and when I put the motor together I don't wont to worry about leaks. Any Advice?
Old Aug 6, 2006 | 10:08 PM
Javier97Z28's Avatar
Moderator
I used a new OEM GM gasket with my Milodon pan, 0, zilch, nada leaks from my pan.
Old Aug 6, 2006 | 10:09 PM
1racerdude's Avatar
It's a cork side, neoprene end gasket that has been used on SBC since '55.
Old Jan 2, 2007 | 03:33 PM
seawolf06's Avatar
Are these truly the same gasket? The one from Autozone said felpro on the computer, but the box says ROL. It's also orange instead of the black like all the pics I've seen. I just don't want this thing to leak. Thanks.
Old Jan 2, 2007 | 07:18 PM
Not sure about the ROL gasket but you can use either of those felpro part numbers. I get mine from Summit. The 1886 is blue.
Old Jan 2, 2007 | 07:21 PM
seawolf06's Avatar
Well, it's in an ROL box and it's orange, but it has that part number on the box, OS34500R.
Old Jan 2, 2007 | 08:41 PM
Dave89IROC's Avatar
ROL uses the same numbers as Fel-Pro
you got a ROL gasket from autozone?I know Murray's has the ROL stuff
last oil pan gasket I got(for my LT1 in the K5) was the OS34500R, Fel-Pro
Old Jan 2, 2007 | 09:42 PM
seawolf06's Avatar
And it came in the Felpro box? What color was it?
Old Jan 3, 2007 | 06:15 AM
Dave89IROC's Avatar
the gasket? blue
and yes, It was a felpro box
Old Jan 3, 2007 | 08:42 PM
cdb95z28's Avatar
I`ve used the FP OS34500R before, it never leaked. Just make sure everything is real clean, and use a LITTLE bit of grey RTV at the junctions of block/rear main seal housing and block /timing cover. I also use a little on the timing cover and rear main seal housing themselves where the gasket touches. And don`t overtorque!
Old Jan 3, 2007 | 10:07 PM
1989CamaroLT4's Avatar
The gasket you got was made by a company named ROL, they make their gaskets in Montreal, Canada. AutoZone is just using the Fel-Pro numbering system, that is common in parts stores when they switch lines.
When you have a rubber gasket that is colored like that I think that is just a given manufacturers' way of identifying compounds- meaning they always know an orange gasket is such-and-such compound, a blue is such-and-such, and so on.
HectorM52
Jul 30, 2017 11:46 AM
willismoons
May 27, 2015 04:03 PM
4586
Apr 29, 2015 01:43 PM
SergheiS
Apr 26, 2015 08:15 PM
Queens94z28
Dec 20, 2014 09:11 PM
