Felpro Oil pan gasket
Re: Felpro Oil pan gasket
Originally Posted by Heatmaker
Anyone know the Felpro p number for the oil pan gasket?
That is if ya are running one. I just ain't had good luck with the silicone gaskets with the crush spacers either Ford or Chevy.
Originally Posted by T/A KID
1racerdude what is the SBC cork gasket, I have a Milidon pan and when I put the motor together I don't wont to worry about leaks. Any Advice?
Are these truly the same gasket? The one from Autozone said felpro on the computer, but the box says ROL. It's also orange instead of the black like all the pics I've seen. I just don't want this thing to leak. Thanks.
I`ve used the FP OS34500R before, it never leaked. Just make sure everything is real clean, and use a LITTLE bit of grey RTV at the junctions of block/rear main seal housing and block /timing cover. I also use a little on the timing cover and rear main seal housing themselves where the gasket touches. And don`t overtorque!
The gasket you got was made by a company named ROL, they make their gaskets in Montreal, Canada. AutoZone is just using the Fel-Pro numbering system, that is common in parts stores when they switch lines.
When you have a rubber gasket that is colored like that I think that is just a given manufacturers' way of identifying compounds- meaning they always know an orange gasket is such-and-such compound, a blue is such-and-such, and so on.
