Felpro
Old Apr 22, 2003 | 11:21 PM
Wildwill532's Avatar
Felpro
I installed the valve cover gaskets again and this time used a ****load of RVT because I wanted it to seal instead of leak and i tightend them down really good. Will this be alright?
Old Apr 22, 2003 | 11:45 PM
96z's Avatar
96z
I would imagine so, mine always seemed to leak though no matter what I tried....
Old Apr 22, 2003 | 11:52 PM
chasmanz28's Avatar
Re: Felpro
let the sealant dry for a day before you start it up, or as long as you can, the longer the better, and did you torque them down the specs i gave you?
Old Apr 22, 2003 | 11:56 PM
INFERNO's Avatar
I use no sealant with stock gm rubbber gaskets. No leaks in 116K miles and I reused them on the new motor and still no leaks.
Old Apr 23, 2003 | 12:03 AM
chasmanz28's Avatar
to each there own, i always smear a little rtv around any seal, just my way of doing things, and for yrs not leaking, many more do
Old Apr 23, 2003 | 09:11 PM
found out whats wrong i think the dip stick has a hole in the side of it at the top so when i would rev it up to a certain rpm the pressure would shoot it out the hole all over the passenger side looking like it was the cylender heads!
Old Apr 23, 2003 | 11:29 PM
chasmanz28's Avatar
thats cool hope you find yr leak, just clean yr engine without getting water on the opti, and look for leaks
Old Apr 23, 2003 | 11:37 PM
I squirted RVT high temp all over the holes 2 of them , i know this wont work forever but i hope it will work temperarly till i can get a new one!
Old Apr 24, 2003 | 12:00 AM
chasmanz28's Avatar
yeah i just did my intake gasket for the first time, seeing how many guys had problems with them leaking after they did the job, took my time cleaned everything, correct toque and no leaks so im happy, only thing im pissed about is the intake gasket going when my car only has 24k on it, you would think gm would have a recall on the gaskets and the flaw in the design, from what ive see on here, manygaskets go, and if you cant fix it yrselve, its a big time labor job for a gm dealer to charge yr ***
magman
Apr 15, 2016 03:08 AM
cliff929
Jun 17, 2004 07:06 PM
Joe Brodman
Jun 16, 2003 12:52 PM
NONO5.0
Mar 12, 2003 09:47 AM
