Fel-pro Copper exaust gaskets
Old Feb 13, 2006 | 11:25 AM
MEAN LT1's Avatar
I was thinking about picking some up and then I got to thinking. Will these really seal or is this a gimmic?. Anyone have any experience with these?
Old Feb 13, 2006 | 04:00 PM
LameRandomName's Avatar
Re: Fel-pro Copper exaust gaskets
If you use the correct procedure, then those cheap cardboard gaskets will seal.
If you don't, then nothing will.
The procedure is: Carry a wrench for tightening your header bolts.
When you put your headers on, tighten up all your bolts to "nice & snug", but not "silly tight". You'll know by feel the difference.
Run the car for 5 minutes, then let it get dead cold. Retighten.
Run the car for 10 minutes, then let it get dead cold again. Retighten.
After that, every time you want to go somewhere in your car, check your header bolts and snug up the loose ones BEFORE going anywhere.
Do this until you fail to find loose bolts three times in a row. This will only take a few trips. Less than 5 before you stop finding loose bolts.
Once you are done with this, you are done. Period.
Check them every couple of months if it makes you feel better.
Old Feb 14, 2006 | 04:21 AM
Guest47904's Avatar
Guest
Putting copper next to aluminum isn't a good idea either. Look here.
http://www.engineersedge.com/galvanic_capatability.htm
Old Feb 14, 2006 | 09:26 AM
tim95z28's Avatar
I could not get them to seal with my headers, they leaked horribly.
I threw them out an went with the normal felpro set which sealed up fine.
Old Feb 14, 2006 | 10:02 AM
Z28LT1_Just_Nasty's Avatar
I'd rather just use the regular felpro's
magman
Apr 15, 2016 03:08 AM
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
WobblySausage
Oct 7, 2015 02:44 PM
pepon214tx
Sep 20, 2015 04:48 PM
