Fastest cam under 6200rpm?
Old Jan 23, 2006 | 08:58 PM
tiznodd's Avatar
Hello everyone, I've been lurking on this board for a while now trying to decide on a cam for my M6 93 Z28, but haven't really come to a solid conclusion. I realize there are 8 trillion Cam threads but none seemed to address my concern of keeping my motor under 6200-6300rpms.
I've narrowed it down to the Hotcam, CC305, CC503 and GM846. The last two I suspect will need to see more rpms than I want, but I'm not positive. I'm basically looking for what cam will make my car the fastest while shifting at 62-6300rpms. The car has all the boltons and will get a pcmforless tune.
I also have to pass a CA dyno smog : (
Thanks,
Todd
Old Jan 23, 2006 | 09:00 PM
speed_demon24's Avatar
Re: Fastest cam under 6200rpm?
Crane 227, 210/224. I ran a 12.4@115 with that cam boggin it out of the hole to save the 10 bolt...
Old Jan 23, 2006 | 09:02 PM
flatlander757's Avatar
IMO I'd talk to Bret Bauer and get a custom grind.
Javier97Z28's Avatar
Moderator
I went as fast as 12.06 @ 112.81 with my XE 224/230 grind. I'm a big fan of the XE grind although I'll be removing it soon in favor of a larger grind and ported heads.
Those times are with stock untouched heads. My A4 was shifting at 6250 rpm.
Old Jan 23, 2006 | 09:08 PM
Bersaglieri's Avatar
Ditto. PM: SStrokerAce for his email or number.
Although the Crane 227, I believe those times were done on ported heads, no?
-Dustin-
Old Jan 23, 2006 | 09:16 PM
streetrod93's Avatar
12.47 @ 115.7 with the cc305...for sale in about 2 weeks
Old Jan 23, 2006 | 09:23 PM
-Dustin-
Yep. I was getting valve float too though, I had worn out springs in it. You couldn't even tell i had a cam in it, its a great sleeper cam. And I miss all the lowend, that thing pulled like crazy from any RPM. If I could do it over I woulda just left that cam in my car..
Old Jan 23, 2006 | 09:31 PM
96capricemgr's Avatar
I have a zz3 cam which is slightly smaller than the Crane 227 210/224 and during the shifts it is topping 6K, the HOT cam and such will have to rev much higher. IMO talk to a custom grinder like Bret or go with something "small" like the 227 there.
Old Jan 24, 2006 | 01:10 AM
tiznodd's Avatar
thanks for the advice everyone...I'm thinking the 227 might be the way to go.
Old Jan 24, 2006 | 10:20 AM
stereomandan's Avatar
227 or custom grind from Bret. (SStrokerace)
Dan
Old Jan 24, 2006 | 10:26 AM
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
I shift my hotcam at 6200
Old Jan 24, 2006 | 10:36 AM
DarkHorse's Avatar
GTP 4, stock heads - NA + bolt ons = 6200rpm shifts and 12.36 @ 110
Old Jan 24, 2006 | 10:50 AM
limige's Avatar
xe230/236
Old Jan 24, 2006 | 06:46 PM
Originally Posted by limige
xe230/236
did you miss the 6200rpm part.
Old Jan 24, 2006 | 06:59 PM
DarkHorse's Avatar
LOL - maybe he short shifts? But then, why buy that big of a cam?
