Fans not comming on, need soem help
Old Sep 22, 2007 | 03:54 PM
solarofthesix
Guest
Posts: n/a
ok so i did a header swap and my fans are not comming on. I didnt have time to investigate this as I gotta goto work and didnt realise it was the fans until I bleed the fudge outta the system. Here is what happened...
I did a header swap lasntight, and in the process I broke the sensor on the driver side head for water temp. Went to ORiley's and got a borg and warner one. Now I am blowing fan fuses(10a) in the fuse box under the hood.
would that sensor be a possible cause for the blowing of fan fuses. If not then tomorrow ill be tracking down to see if I pinched a wire or if somehting else retarded is going on.
Old Sep 22, 2007 | 05:52 PM
The sensor in the head has nothing to do with the fans.
Old Sep 22, 2007 | 11:24 PM
mrmint69's Avatar
I think the sensor your talking about is for the gauge in the car only. I would say a short like if you have a bare wire of the ground wire or connect is messed up.
Old Sep 23, 2007 | 06:02 AM
solarofthesix
Guest
Posts: n/a
iight well ill put it up on the rack this afternoon and find it. gives me a chance to fix a few things. I have a feeling that maybe I pinched a wire somewhere. cant wait to get this problem resolved so I can go have fun hah
Old Sep 23, 2007 | 06:03 AM
solarofthesix
Guest
Posts: n/a
oh and thanks for the input
ChrisFrez
Jan 4, 2015 08:43 AM
ChrisFrez
Dec 15, 2014 03:09 PM
ChrisFrez
Dec 7, 2014 06:01 PM
NewsBot
Dec 3, 2014 12:30 PM
ChrisFrez
Nov 30, 2014 08:41 AM
