Fan Switch
Fan Switch
Installing an SLP switch, wondering whats the best way to get through/around the firewall to the engine. dumb question i know but id rather do it right the first time and thought u guys would know best
Re: Fan Switch
Right behind the PCM, under the hood, there's a perfect spot to run wires (especially for the SLP fan switch). Remove the 2 bolts holding the PCM in place, slide the PCM out of the way, and you'll see the spot.
carguyshu
Jan 22, 2017 11:19 AM
