False Knock retard
Old May 6, 2007 | 07:52 PM
kline454's Avatar
False Knock retard
My and my friends car both are pulling about 3-5 degrees of timing at idle or going down the road both have lt4 knock module,both cc306 RR headers and bolt ons, have tryed 110 gas, after all the test we came down to it being the knock sensor being to sensitive of valve train, Anyone else have this problem what are you doing to fix it? thanks kyle.
Old May 6, 2007 | 08:09 PM
solarofthesix
Guest
Posts: n/a
i had mine edited out of the pcm becuase the amount of knock it was reading was insane and the guy doing my tune said "if your knock was that bad you would hear it VERY loudly and wouldnt need a laptop to tell you you had a bad knock." This was done right after a full rebuilt with the lt4HC kit
Old May 7, 2007 | 09:00 AM
kline454's Avatar
so the tuner can make it less sensitive? I know madz28 made it for it can only pull a max of 5 degrees. but can they make it less sensitive to false knock?? my thing is im already losing timing with the 150 shot tune im using so i dont want to lose any to false knock,
Old May 7, 2007 | 11:25 AM
96ZCamaro's Avatar
Same problem here. It is pulling atleast 1 to 2 degree's of timeing at all times.
Old May 7, 2007 | 12:17 PM
transamws6_97's Avatar
yeah you can get knock retard completely tuned out
Old May 7, 2007 | 01:43 PM
kline454's Avatar
ok if i get it completly tuned out will it ever pull timing?? are they just making it for its never will pull any timing?
Old May 7, 2007 | 04:58 PM
1racerdude's Avatar
Wonder how we ran in the '60's without timing retard?
Don't worry bout it get a dyno tune and let um set the RIGHT timing for the engine.
Old May 7, 2007 | 08:18 PM
FASTFATBOY's Avatar
Do a search, you can put a resistor in line and ground it to satisfy the computer, unhook the wire from the sensor.
David
94Maroz28
Oct 27, 2015 04:38 PM
football4life
Oct 4, 2015 07:48 AM
SergheiS
Sep 29, 2015 08:56 PM
drt
Sep 27, 2015 04:39 PM
SEOJustin
Sep 24, 2015 04:39 PM
