False Knock
My 1995 camaro will pull timing all the time. So i had to by pass the knock sensor with a resistor, Im using lt4 knock module and no matter what i do if i hook back up the knock sensor it pulls timing at idle in gear going down the road, it sometimes pulls 1 degree and others pull 5 degrees. I have replaced the knock sensor and tried my old lt1 module same problem, It will do this on stock tune or MadZ28 tune, and nothing is hitting the frame or anything, anyone else have this problem?
Re: False Knock
Any chance there's an ignition wire in close proximity to the knock sensor wire? And chance the motor mount, which is right next to the knock sensor, is loose? Have you tried some high octane fuel to see if it reduces the knock retard? What brand RR's do you have?
Re: False Knock
Yes i have use 100 and 110 octane and no diff made, but there is a wire right by the knock sensor wire, and the motor mounts are tight there are proforms 1.6rr not the best but this problem didnt start until well after they where installed
Re: False Knock
I ran a plug wire right next to the knock sensor wire for the headers.
Re: False Knock
You don't want a high voltage wire (like a spark plug wire) near the knock sensor wire. If you have an O2 extension nearby, its not going to matter.
How tight did you screw the knock sensor into the block? When did the problem start? What was the last thing you did before the knock retard showed up? |
Re: False Knock
I made sure i didnt get it to tight, The other problem is i dont know when the false knock started, It wasnt there after the 1.6rr but it was there when i put the madz28 tune in, and i did a lot of work to the car over that time period. like cam headers msd,
Re: False Knock
How do you know its pulling timing. Do you have a Scanmaster?
Re: False Knock
I used data master and the tech 2 at my work.
| All times are GMT -5. The time now is 09:35 AM. |
