FAlse Knock
Old Jun 14, 2004 | 02:30 AM
SloLt1Z's Avatar
FAlse Knock
My car is getting all kinds of false knock 9 degrees on start up and idle. I want to figure out a way to find the cause and fix it. The car used to never show knock retard unless I was whipping on it on my old setup(7 psi P1sc, boltons and stock motor).
Old Jun 14, 2004 | 03:12 AM
1982z28with18s's Avatar
I'm guessing you already have the lt4 KM. Do you just get it at idle or all the time? I used to get 7-9 degrees at idle and 2-4 when cruising and 5-8 when at WOT. I ran some 104 octane in it and it still did it which leads me to believe its not real knock. I'm heads/cam on stock bottem end so my motor should be fine on pump gas. Mine was picking up false knock from somewhere and we never did figure it out, I even changed out the knock sensor. Finally I just programmed it out at wot. I also had a friend with a 94 z28 with an ati procharger on it and he had the same problem back when he had the car.
Old Jun 14, 2004 | 12:42 PM
SloLt1Z's Avatar
I get it all time the, even when it was full of 110 octane i was still seeing between 5 and 9.
Old Jun 14, 2004 | 01:33 PM
LWillmann's Avatar
A bad knock sensor, if the wire is bad or the knock module itself is bad you could see what you're describing.
I supposed you'd also get it if the knock sensor isn't torqued properly.
Old Jun 15, 2004 | 12:23 AM
I tried different knock modules also, and torqued the sensor to different specs and still got the knock reading.
94Maroz28
Oct 27, 2015 04:38 PM
football4life
Oct 4, 2015 07:48 AM
SergheiS
Sep 29, 2015 08:56 PM
drt
Sep 27, 2015 04:39 PM
SEOJustin
Sep 24, 2015 04:39 PM
