? on false ignition knock
Old Aug 27, 2010 | 10:17 AM
a4z28's Avatar
My headers are hitting my heat shield on my car and it is rattling like crazy, my question is can that rattling from the header hitting cause the pcm to retard the timing and cause a false knock? My car has a tune from pcmforless for my boltons and when i use to have nitrous so i know it has timing pulled already but some times it feels like the car is nose diving like there is a timing retard issue. Can the knock module be deleted from the pcm? Thanks
Old Aug 27, 2010 | 11:52 AM
RamAir95TA's Avatar
The knock module cannot be deleted. You can have the knock sensor circuit programmed to your liking though.
But the obvious thing to do here would be to fix your heat shield. Not to mention get the car on a scanner to see if you're getting false knock.
Old Aug 27, 2010 | 12:16 PM
a4z28's Avatar
So am i right for thinking that it is possible for the rattling to cause false knock?
Old Aug 27, 2010 | 02:22 PM
RamAir95TA's Avatar
Yes, it's possible.
Old Aug 27, 2010 | 02:37 PM
sepno77's Avatar
Several things can cause this issues, ign, fuel, tune, ect...
my question is can that rattling from the header hitting cause the pcm to retard the timing and cause a false knock? Yes, its possible.
My brothers old car had a very bad rattle but when tuned they normally desensitize the knock module so it would hardly affect performance.
Old Aug 27, 2010 | 04:25 PM
a4z28's Avatar
I wil be fixing this tommorow and see if i see an improvement. thanks
Old Aug 29, 2010 | 09:46 PM
a4z28's Avatar
There was a huge improvement... I cant belive the difference. It had to be retarding timing.
93 RedBird
Nov 15, 2015 08:24 AM
94Maroz28
Oct 27, 2015 04:38 PM
IndyZman
Oct 22, 2015 02:17 PM
PopoFormula
Oct 12, 2015 04:19 PM
SEOJustin
Sep 24, 2015 04:39 PM
