Factory Temp Sending unit on 95 camaro.
Old Jun 20, 2009 | 08:44 PM
Final03's Avatar
Anyone know exactly where this is on a 95 camaro.... I'm trying to find it because i am trying to get my dash temp to work... I don't know if i forgot to hook it up or if i need to purchase a new one but i can't seem to find it..
Any easy way of tellin me where it is?
Thanks for the help.
Old Jun 20, 2009 | 09:28 PM
RamAir95TA's Avatar
There are two coolant temp sensors. The one you are looking for is located on the driver side cylinder head between cylinders 1 and 3. It has a gray plug with a one-wire connection.
The other sensor is for the PCM, and is located in the water pump housing.
Old Jun 20, 2009 | 10:08 PM
http://shbox.com/1/temp_sensor2.jpg
http://shbox.com/1/4th_gen_tech2.html#ect
Old Jun 20, 2009 | 10:24 PM
Final03's Avatar
Thanks that helps me a lot more than the book i was lookin at hard to tell where it was from the book.
Old Jun 21, 2009 | 10:27 AM
Final03's Avatar
I looked this morning and there was just a flat spot there so i dunno if the person before me plugged it or not... But this engine was out of a 94 caparice does that make any difference as to where it would be located or still located the same place?
Old Jun 21, 2009 | 03:24 PM
All LT1 water pumps have the hole for the temp sensor in the same place. Perhaps you were looking at the boss that is closed on non-f-body pumps that goes to the oil cooler bypass hose.
Look here to compare:
http://shbox.com/1/lt1_water_pumps.jpg
Old Jun 21, 2009 | 05:04 PM
Final03's Avatar
The one on the water pump is fine... I'm lookin to make the gauge on the inside of my dash work it worked before we put this engine in ... So i'll have to double check again but i didn't see a hole or a bolt there to plug it... Which the person who had this engine b4 me put a lot of plug offs in it so i didn't know if maybe there was another spot for this temp sending unit to be for the gauages to work
Old Jun 21, 2009 | 05:07 PM
RamAir95TA's Avatar
Here. You can see the location in this picture of my motor. It's the gray plug between the first and third cylinder.
Old Jun 21, 2009 | 10:11 PM
BADAZZ_Z
Parts Wanted
Mar 5, 2019 12:55 AM
RUENUF
Mar 13, 2016 03:39 PM
transam_388
Mar 15, 2015 11:53 AM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
