Factory computer limit of 93 computer? 7K??
Old Sep 30, 2003 | 09:18 AM
DRAGRACR's Avatar
I have a 92 vette, and it has the same computer as you guys 93 computers, and the question that I have is if you guys know what the limit is of the computer? My car is banging at 7000 and I was wondering if the computer shuts off at that or I may have some other issue. My Tuner Cat table goes to 7500, and my rev limiters are set to 8K.
Old Sep 30, 2003 | 09:19 AM
jasons93z's Avatar
does it just "surge" at the top end.
NewbieWar's Avatar
damn the vette gets a lot more rpm's then the camaros...
Old Sep 30, 2003 | 09:21 AM
jasons93z's Avatar
im assuming he has a cam or other stuff done to it because its the same engine, duh
Old Sep 30, 2003 | 09:24 AM
DRAGRACR's Avatar
No surging, just like hitting the factory rev limiter. Btw : I have a balanced bottom end and a solid roller. The vettes do not come factory with a 7k limiter, I removed the factory settings.
Old Sep 30, 2003 | 09:29 AM
jasons93z's Avatar
Check the programming and make sure that it is set at 7k, if its not my next guess would be the coil. It cause me to have high rpm problems when it went. Its a cheap replacement, just replace that and the coil wire.
Old Sep 30, 2003 | 09:40 AM
DRAGRACR's Avatar
That is the thing my rev limiter is now set at 8K and it will only go to 7K and I was wondering if that is all that the factory computer would go is 7K.
Old Sep 30, 2003 | 09:43 AM
jasons93z's Avatar
I dont think so If you set the rev limiter to 8k it should go to 8k. Thats pretty high though, what kinda motor u got there . What about the coil, seems to simple to be true, but have you checked the coil?
Old Sep 30, 2003 | 09:46 AM
DRAGRACR's Avatar
No, I haven't started digging in the motor yet, but I thought that I remembered something about the factory computer only being good to 7k. Just wanted to make certain of this before I go chasing my tail......
Old Sep 30, 2003 | 09:48 AM
jasons93z's Avatar
Yeah, if you have the limiter set at 8k it WILL go to 8k
Old Sep 30, 2003 | 09:58 AM
LT4POWR's Avatar
I believe the stock PCM is only good to 7160 rpms.
Old Sep 30, 2003 | 10:04 AM
DRAGRACR's Avatar
Well that is what I was afraid of...... Anyone else????
Old Sep 30, 2003 | 11:16 AM
Jason Dove's Avatar
You may be better off moving this to the Computer Diagnostics/Programming Section of the board.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
May 8, 2015 11:30 AM
IDOXLR8
Aug 6, 2002 12:30 PM
