Factor freak?
Old Jun 22, 2003 | 10:54 PM
kaoticcamaross's Avatar
Factor freak?
My car is a 95 z28 and has been some what modified by me but thats beside the point. I was looking at the gage cluster on my car and it only goes up to 120. Do some z28's have gage clusters that go up to 120 or did soem one replace the gage cluster? I'm just wondering maybe some one could help. Thanks
Wes
Old Jun 22, 2003 | 10:56 PM
jasons93z's Avatar
yours didnt come with z rated tires from the factory so it has a limiter on it. Mine came with z rated tires so it has the 150 speedo and no limiter on it
Old Jun 22, 2003 | 10:57 PM
craigffb's Avatar
The car came from the factory with non Z rated tires. That's why your speedo only goes up to 125. You also have a gov. if you haven't disabled it or didn't know. So to answer your question, yes some cars came with the 125 speedo.
Old Jun 22, 2003 | 11:28 PM
LT1ponykilla's Avatar
And to get that gov. off all you have to do is get a programmer of some kind!
Old Jun 22, 2003 | 11:40 PM
Blue89Bird's Avatar
unless you upgrade to Z rated tires, I wouldn't go about removing the speed limiter.
Old Jun 23, 2003 | 12:03 AM
Formulated's Avatar
So how do I get rid of the governor if I am going to get Z-Rated Tires?
Old Jun 23, 2003 | 12:33 AM
Blue89Bird's Avatar
www.madz28.com
Old Jun 23, 2003 | 12:44 AM
jasons93z's Avatar
Send your pcm to pcmforless or get a programmer and do it yourself. But who needs to go more than 114 . J/K
Old Jun 23, 2003 | 08:03 PM
Dragon Racing's Avatar
Didnt the cars that had the 120mph speedo and non z-rated tires also only come with 2.73's? Or am i wrong?
Old Jun 23, 2003 | 08:14 PM
Kris93/95Z28's Avatar
Yes I believe that I read somewhere that if you have 3.23s you MUST have Z-Rated tires.
Yet you can have Z-Rated tires and 2.73s
Old Jun 24, 2003 | 06:38 AM
How can I find out which gears i have?
Old Jun 24, 2003 | 07:18 AM
indy500ss's Avatar
Look at your options tag, I believe it should be in your glove box. The cars with the 3.23's had RPO G92, not positive but I am pretty sure that is right. As for the 125mph speedo and 3.23's, I believe those were to different options. I know with 3.23's you got the engine oil cooler.
Old Jun 24, 2003 | 08:00 AM
anaik's Avatar
With the A4 came 2.73 (GU2) or 3.23 (GU5) If M6, '94 up came with 3.42 (GU6).
Old Jun 24, 2003 | 08:06 AM
DropZ
Guest
Posts: n/a
Another way to tell is to look at your shifter. If it has a "1" selection, you have 3.23 gears. If the lowest gear you can select is "2" you have 2.73's.
Old Jun 24, 2003 | 08:59 AM
hairbear21's Avatar
Not all cars received the oil cooler. It was "supposed" to be an automatice option once you went with the 3.23's "performance axle", but not all recieved the cooler. It may also only be for the northern climate cars as well. Maybe the reason mine doesn't have one?
BTW, no no one has taken it off, it's not even listed in my RPO codes
