Exposed helicoil tips after ported heads, did you take them off?
Old May 13, 2006 | 12:16 PM
Javier97Z28's Avatar
Moderator
When I sent my LE2 heads to a local race shop to have them "once overed" after my bent valve situation, he told me that I should really break the tips off the end of the helicoil for the rocker studs. They're exposed and of course with the longer comp (arp) rocker studs they are bent out some.
Has anyone ever done this? They don't seem like they're going anywhere, but I could see how it would be a problem if by chance they did overtime. Only seems to be an issue on the intake side studs...
Old May 13, 2006 | 12:24 PM
SStrokerAce's Avatar
Re: Exposed helicoil tips after ported heads, did you take them off?
You can break them off with a screw driver if you want, it's not going to hurt anything.
The dude didnt put a new valve job in the heads hopefully.
Bret
Old May 13, 2006 | 12:27 PM
marshall93z's Avatar
Why is there helicoils in the head?
Old May 13, 2006 | 12:33 PM
Moderator
Bret
Negative, just checked all the valves to make sure they were sealing and cleaned them for me. Then just replaced the one bent valve with a new Ferrara replacement (same series)
I'm gonna leave this crap alone, those helicoil tips are hard as hell and it's starting to actually pull down on the helicoil strips the more I try to break them off.
Marshall, the rocker stud threads are helicoils from the factory.
Old May 13, 2006 | 12:46 PM
Good as long as he didn't change the installed height on the springs like that guy did with Lloyd's heads you will golden.
Bret
Old May 13, 2006 | 12:48 PM
Moderator
Bret
Yah, nothing like that at all...
BUT now I think the helicoil on that rocker stud is ****ed up. I can't for the life of me get the tab I started to mess with to come off and now the final loop of thread at the bottom of the heli coil is starting to go into the intake port.
Is it possible to remove the helicoil and replace it with no drilling?
GOD WHY DO I LISTEN TO PEOPLE SOMETIMES
Old May 13, 2006 | 01:19 PM
dont let the helicoil turn in the threads that will give you some headaches
Old May 13, 2006 | 01:20 PM
Moderator
too late it looks like...
what now?
Can I remove it and replace it w/o drilling? I think I've read about some helicoil removal tools
Old May 13, 2006 | 01:21 PM
10-4! Never had one out.
Old May 13, 2006 | 01:25 PM
what now?
Yeah but you dont want to break that tab off if you want to get it out.
Are there still threads at the top of the hole?
Bret
Old May 13, 2006 | 01:33 PM
Moderator
I'll take two pics of the situation, brb in 3 minutes or so
Old May 13, 2006 | 01:41 PM
Moderator
Ok, it's the stud on the right...
Old May 13, 2006 | 01:57 PM
Yeah thats at least one thread down, maybe take it back to the machinest that told you to do it and see if he will replace it.
Bret
Old May 13, 2006 | 02:06 PM
Moderator
Gotcha. I'd like to avoid taking it to him or anyone at this point. Let me see if I can find something to remove it with locally, and if I can even find the right helicoil.
Old May 13, 2006 | 02:27 PM
The helicoli is not hard to find.
